June 28, 2017, 09:40 |
FLUENT UDF for heat transfer coefficient
Zaranyika Parents Kumbirai
i am new to fluent and i am simulating flow around a hot cylinder mounted inbetween two cold plate and would like to plot contours of the convective heat transfer coefficient around the cylinder and at the base plate. Is there a way of creating a UDF for this or another way that gets me the same result? please is you can include a detailed explanation/tutorials in your answer that would be swell
July 9, 2017, 15:30 |
sandy
Rep Power: 10 |
as far as i know fluent writes a no of fields to your output files.].dat]
just add heat transfer coefficient from list of variables you want to save. thats it. you are done |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
temperature dependent Heat transfer coefficient using UDF | Koham | Fluent UDF and Scheme Programming | 0 | January 5, 2016 09:50 |
Calculation of lift/drag coefficient by FLUENT UDF | rsarma | Fluent UDF and Scheme Programming | 0 | August 5, 2015 06:16 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 18:30 |
UDF for Heat transfer coefficient | Dong Wenchao | FLUENT | 2 | August 23, 2006 07:35 |
