February 21, 2017, 03:58 |
dt in the method of characteristics
I am solving Navier-Stokes equation using the finite element library Rheolof.
To model the advection, they have used method of characteristics. see link below page 86 of https://cel.archives-ouvertes.fr/cel...70v13/document. As I use larger values of Re, I need a larger dt in the code so that du/dt actually shrinks and I eventually get the steady solution. This is counter-intuitive because I always imagined, the more complicated the problem, the shorter dt has to be. Can anyone shed some light on the method, and the role of that dt. and if there is any condition that needs to be satisfied for convergence (something similar to CFL condition)? Thanks |
cfl condition, characteristics |
The finite element method - “displacement” or “stiffness” method | 3Lin7 | ANSYS | 0 | February 15, 2013 19:36 |
Control volume based finite difference method? | mukut.medhi | Main CFD Forum | 3 | August 24, 2012 11:01 |
About flowfield-dependent variation(FDV) method? | Jinwon | Main CFD Forum | 1 | December 4, 2007 22:13 |
Info on method of lines approach | charlie ryan | Main CFD Forum | 2 | August 9, 2007 12:06 |
Want someone to discuss regarding ADADTIVE GRID METHODOLOGY AND THE METHOD OF CHARACTERISTICS. | RAGHURAM K.S | Main CFD Forum | 1 | February 15, 1999 13:21 |
