November 29, 2016, 07:01 |
Abaqus CFD
Marcel
Hey guys,
i am writing a thesis for my master degree in engineering about a numerical simulation of incompressible flow for a welding process(simulation of the inert gas flow). I am using Abaqus/CFD for the simulation and i have no real contact person for the software and CFD simulation in general, so i have to make many decisions by my own. Is there someone who i can ask some questions/ who use abaqus for CFD simulation? One important element of the simulation will be a sinter element. It will be handled as flow through a porous medium. I have a curve from the producer of the filter(sinter element), pressure loss over velocity of fluid. So i wanted to validate my model with this curve. The equation of the pressure loss cause of this filter is giving by: first picture attached In Abaqus there is this equation given to simulate porous flow: second picture attached v is the extrinsic average or the superficial velocity vector, where the average is taken over a representative volume incorporating both the solid (matrix) and the fluid phases; p is the intrinsic average of the pressure (average taken only over the fluid-phase); rho is the density of the fluid; müh is the viscosity of the fluid; epsilon is the porosity (volume fraction of the fluid phase) of the porous medium; and K is the permeability of the porous medium. I have all parameters for the modell but i dont understand how the abaqus model considers a length of the filter element. If i vary the length of the sinter element it will result in a different pressure loss. Which seems logical for me but i cant see how abaqus/CFD consider a length of the filterelement with this given equation. And the tutorial for porous flow in abaqus is a little bit misleading. It says that i need to define a porous section. If i do he wont run. But if i only use the drag force feature in the wanted section and when i write the needed parameters into the fluid material properties then it run. Which seems weird cause the porosity is a property of the filter, not the fluid. Thanks for your help |
November 29, 2016, 07:13 |
Marcel
Hello hello hello
Abaqus - CFD | Morocotopo | Main CFD Forum | 0 | October 19, 2012 03:35 |
ICEM CFD working together with ABAQUS | Jim | CFX | 0 | March 24, 2006 07:10 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 21, 2000 04:49 |
PC vs. Workstation | Tim Franke | Main CFD Forum | 5 | September 29, 1999 15:01 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
