October 20, 2016, 11:47 |
Transient Solution Problem
Rep Power: 10 |
I would like to ask question about transient solution.
The model which I work on reach steady state conditions after approxiamately 10800s. I added picture. I analyzed as statedy state solution. But result is not same transient solution due to the time scale reach steady state is very large. I will try to analyze as transient solution. time step < (smallest mesh size/velocity) time step < 0.0006s For 10800s Time step size 0.0005 Number of time step 21600000 This take long time. How can I solve this problem. Is there sımple way for this. Can you advise me. Thank you in advance Best Regards |
October 21, 2016, 01:00 |
babanpreet singh
Rep Power: 10 |
Try to do steady state with density and chose implicit approach
October 21, 2016, 04:35 |
Rep Power: 10 |
Thank you for your answer. Could you please explain a little more.
October 21, 2016, 05:56 |
#4 | |
Adarsh Tiwari
Rep Power: 10 |
in implicit method, the solution progresses stably, hence possible to get the desired solution. Whatever may be the solution method, it is important to analyze with reference to the physics of the problem.
If you can send a brief writeup about you case, we can provide you the specific solution for your case. you can send text messages on: http://workshopwale.com/ or can email at: adarsh@workshopwale.com Quote:
October 22, 2016, 04:04 |
#5 | |
Rep Power: 10 |
Best Regards. |
October 22, 2016, 06:33 |
babanpreet singh
Rep Power: 10 |
Actually the thing is in implicit the number of equations to be solved is same as tge number of variable hence a constructive approach is made to all the equations but in explicit each variable have different equation easy to solve but explocit depends on time where as implicit is time independent
October 22, 2016, 10:16 |
#7 | |
Rep Power: 10 |
Thank you for your answer. I will try. and share result. |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Future CFD Research | Jas | Main CFD Forum | 10 | March 30, 2013 12:26 |
Problem with transient solution of flow past a row of cylinders | jostanek | Main CFD Forum | 0 | January 6, 2010 12:16 |
Convergence problem | suthichock | Main CFD Forum | 27 | May 11, 2009 07:05 |
Transient problem! | Jamesdclimber | CFX | 8 | February 11, 2005 15:43 |
