Flow through a simple porous rectangular channel |
October 3, 2016, 08:09 |
kiran
Rep Power: 9 |
Hello there, i was very new to FLUENT and working on porous walls, imagine i have a hollow rectangular channel with so and so geometry... I have created 2 frozens in which the fluid flows through inside channel(frozen2) and outside channel or material(frozen1) could be porous wall with 0.45 porosity. My porous material could be cordierite... i have blocked the outlet and made it as wall so that let me see the flow through the porous walls. I used to run the simulation,,, but velocity and pressure streamlines are not flowing through walls of channel. so, shall i have to alter the things? or i am in wrong way? or i have to define the porous material and change aluminium to blah blah.. with external paramaters???? please give me the wayyy... this helps me lot and go through my project.... MANY THANKS... |
October 3, 2016, 08:12 |
#2 | |
kiran
Rep Power: 9 |
October 4, 2016, 02:00 |
babanpreet singh
Rep Power: 10 |
U need to set fluid domain in which the fluid from porous wall would flow into as the porous wall is acting as simple wall because it is not outlet. You could mail me details babanjaria@hotmail.com and i can help you out.
October 21, 2016, 10:05 |
#4 | |
Adarsh Tiwari
Rep Power: 10 |
Hi Kiran,
You can send a small write-up about your case to http://workshopwale.com/ or can email us at: adarsh@workshopwale.com. We have a proven track record of completing projects on time. Regards, Workshopwale Team!! KBAT Technologies Pvt. Ltd. Quote:
How do I prescribe Average Velocity /Total Inlet Flow for a simple channel problem? | skuznet | OpenFOAM Pre-Processing | 4 | February 16, 2022 09:44 |
Turbulent transition in channel flow | yansheng | STAR-CCM+ | 11 | June 16, 2016 09:05 |
Question on the boundary condition for open channel flow, please help! | ripperjack | OpenFOAM Running, Solving & CFD | 0 | September 13, 2013 11:44 |
Gravitational water flow in closed channel. | Szymon85 | CFX | 7 | September 3, 2013 16:28 |
Porous Media coupled with internal flow | Samuel Andrade | FLUENT | 2 | August 26, 2012 09:43 |
