Home > Forums > General Forums > CFD Freelancers
3D Airfoil with Sharp Trailing Edge - Mesh Help
Old   August 8, 2016, 20:28
Default 3D Airfoil with Sharp Trailing Edge - Mesh Help
Alex Toofanian
Toofanian is on a distinguished road
Hi all,
I am using the ANSYS Workbench 16.2 meshing application to mesh a 3D flow domain for use in Fluent.
When I add inflation layers to my mesh, they produce highly skewed cells around the trailing edge of the airfoils, since they come to a sharp point. How can I resolve this? I have seen some solutions posted, but none for this software.
Screencap of current mesh attempt:
Thanks,
Toofanian
Toofanian is offline   Reply With Quote
Old   August 15, 2016, 19:03
Default Potential Solution
cfd_guy
krishna13j is on a distinguished road
Hi Toofanian(nice name),
It would not be too bad a trade-off to switch to ICEM block structured meshing if you're still facing the issue with your mesh. C-grid is a best practice for airfoils
Best.
krishna13j is offline   Reply With Quote
airfoil 3d, inflation layers, mesh 3d
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 18:27
[ICEM] Sharp leading and trailing edge airfoil matters_100 ANSYS Meshing & Geometry 10 April 5, 2016 15:20
4-digit NACA airfoil: Trailing edge of the airfoil is not quite zero sisi Main CFD Forum 5 October 1, 2014 11:00
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
