Home > Forums > General Forums > CFD Freelancers
Problem with plotting on a curve length
Old   June 22, 2016, 18:08
Default Problem with plotting on a curve length
mariusam is on a distinguished road
I'm currently working on the modelisation of a 180 degree bend pipe in 2D. I would like to plot the pressure coefficient along the inner and outer wall of my pipe. I created a named selction for the "wall in" and "wall out".
In Fluent i chose Results->Plots->XY Plot->Set Up and then i tried to plot on the Y axis the Pressure Coefficient and on the X axis the Curved Length. As i selected the "Wall in" as surface to plot Pressure Coefficient, an error message appear. It does the same thing for all surfaces available.
I put a screenshot for you to see better
Does anyone had the same problem and resolved it ?
Another question : Does anyone of you know how to plot along a curved length on CFD-Post ?
Thank you for your answers
mariusam is offline   Reply With Quote
Old   July 26, 2016, 15:53
Matt Levins
mattlevins is on a distinguished road
Please email me at ml02534@georgiasouthern.edu with you details and I will be glad to take a look
Regards
mattlevins is offline   Reply With Quote
Old   July 26, 2016, 16:37
thank you for your proposal but we found a solution. we did it on excel computing the curve length with the exported data in function of x and y.
thank you
Old   July 26, 2016, 17:32
Matt Levins
Exactly. I had a similar problem when modeling external flow over a cylinder to compute far field sound..
What is the reason you are simulating this? Just basic pipe flow and pressure losses?
cfd-post, curve length, fluent, plot, pressure coefficient
[General] Problem of plotting Nusselt number versus length of tube using Paraview‏ princexypn89 ParaView 2 May 11, 2016 13:33
Plotting turbulentce length scale contour Henry Arrigo STAR-CCM+ 2 August 26, 2014 05:34
Fracture mechanics newbie needs help setting up and solving fracture length problem Antst CFD Freelancers 2 August 17, 2013 03:13
problem in plotting cl curve kiran FLUENT 5 August 11, 2004 12:04
y+ - plotting problem -cfx5.4.1 joseph CFX 2 September 7, 2001 11:06
