Home > Forums > General Forums > CFD Freelancers
Very small job: converting an OpenFOAM mesh to a format needed by another code
Old   June 11, 2016, 17:08
Default Very small job: converting an OpenFOAM mesh to a format needed by another code
SFr
SFr is on a distinguished road
I need to run a benchmark to compare a result based on OpenFOAM/interFoam with a result from another code.
I'd like to use a mesh that is similar for both codes. The other code does not have a great meshing tool, so I'd like to export the OpenFOAM mesh in a form that can be used by the other code. The file attached here, "mesh.txt" shows an example format of a mesh for the other code.
This kind of thing is not straightforward for me, but maybe there's someone out there who would find it easy to do. If you're interested, please PM me and I can provide any further details, including my OpenFOAM mesh. Thank you.
SFr is offline   Reply With Quote
Old   June 24, 2016, 06:45
Totalsim's Avatar
Jon
Totalsim is on a distinguished road
TS might be able to help.
What is the other code? We have converted OpenFOAM meshes into formats most commercial codes can read.
Email us if you have not already sorted it. info@totalsim.co.uk
TotalSim CFD Engineer
www.totalsimulation.co.uk
Totalsim is offline   Reply With Quote
mesh, mesh 2d, mesh adaptation, mesh adaption, mesh and grid
Tool to convert OpenFoam mesh to SU2 mesh (2D and 3D) Combas SU2 45 October 16, 2024 18:26
[Commercial meshers] converting Ensight gold format mesh to OF Kossivi OpenFOAM Meshing & Mesh Conversion 1 June 6, 2020 02:39
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 06:59
Converting a Fluent Mesh with Porous Jump into OpenFOAM mesh with porousBaffle billwangard OpenFOAM Pre-Processing 1 February 19, 2015 10:07
[Other] How to convert a mesh into openfoam format jr33 OpenFOAM Meshing & Mesh Conversion 1 October 2, 2012 18:20
