Home > Forums > General Forums > CFD Freelancers
Seeking help with cross-flow water turbine analyses (prefer COMSOL)
Old   May 23, 2016, 13:15
Default Seeking help with cross-flow water turbine analyses (prefer COMSOL)
Patrick Kelecy
pkelecy is on a distinguished road
Hi All,
I am looking for someone to develop a CFD model of hydrokinetic water turbine in cross flow. The turbine will have active blade pitch control, so the model needs to accommodate both the rotation of the blades as well as changes in blade pitch with rotation. The model will be used to conduct parametric studies of the turbine and to predict moments on both the turbine shaft and blades during operation.
My thought is to start with a 2D model of the turbine, as the geometry lends itself to that, but possibly do a 3D model as well (for comparison) if time and cost permit.
I would prefer to have the model developed in COMSOL, as that is what I use for other analysis work I do and it would possibly allow me to run the model, if wanted. However, using COMSOL is not an absolute requirement, and if other CFD codes can do this work more efficiently, accurately, or cheaply, I'm all for it.
Let me know if you're interested. I am particularly looking for someone with prior experience doing similar types of analyses to this. Thanks!
pkelecy is offline   Reply With Quote
Old   May 23, 2016, 14:39
Default Hello
Rohan sharma
rohansharmafree is on a distinguished road
I have 8 years of experience in CFD analysis. I have performed all kinds of CFD analysis in various CFD software (Ansys CFX, Fluent, etc) .
I have performed many hydrodynamic simulation in past. To comment on your project more accurately. I need some more information. Please send me a personal mail (rohansharmafree@gmail.com) or Skype (rohansharmafree)
Regards
Rohan
rohansharmafree is offline   Reply With Quote
Old   May 24, 2016, 02:11
Adarsh Tiwari
Workshop Technologies is on a distinguished road
HI Patrick,
I suggest you to go for OpenFOAM, it is free to use and you can also modify the source-code as per the requirements.
We have a proven track record of completing the projects well within time and at most affordable cost.
We are best-in-class single window solution provider for CAD, CFD, CAE, Automation, Machine Design, Manufacturing, Web-Design, Digital Marketing and SEO.
You can check our profile at: http://workshopwale.com and you can also mail us at: adarsh@workshopwale.com.
Thank You.
Regards,
Originally Posted by pkelecy View Post
Hi All,
Workshop Technologies is offline   Reply With Quote
Water turbine CFD modeling Peter Main CFD Forum 7 April 4, 2016 03:31
Mass Flow rate in spray water modeling Behnam Ghadimi FLUENT 0 June 8, 2013 17:05
Mass Flow rate in spray water modeling Behnam Ghadimi Main CFD Forum 0 June 8, 2013 16:48
Water jet in confined hot air cross flow Jim Clancy FLUENT 0 November 24, 2007 17:14
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 08:15
