Temperature limited to 1k in so many cells in domain 1 |
February 26, 2016, 08:39 |
Swapnil Narkhede
Hello all...
I am doing CFD simulation for a shell and tube heat exchanger where in tubes have fin profiles same as ceiling fans... now when I go for mesh;till volume mesh the quality is 0.2 but after doing prism mesh the quality drops down to 0... And in fluent,till 30 iterations it goes well..but after that it starts showing that "Temperature limited to 1.00000e00 in so many cells in domain 1.... I have read threads on this forum and tried the solutions described here but couldnt resolve the problem... Plz suggest how to tackle this issue... |
February 26, 2016, 19:25 |
freelancer.cae
Rep Power: 12 |
If you send me mesh and case file at freelancer.cae@gmail.com
I will take a look and let you know how to fix it You can also send me whole ANSYS WB archive. |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
TEMPERATURE LIMITED problem | emanuele | FLUENT | 9 | June 15, 2018 10:45 |
temperature limited - absolute pressure limited | Asashi | FLUENT | 3 | July 18, 2014 09:51 |
temperature limited to 1.0e-00 in 10 cells | fabolous | FLUENT | 1 | July 14, 2010 13:48 |
