Home > Forums > General Forums > CFD Freelancers
General question about SST turbulence model
Old   December 4, 2015, 14:49
Default General question about SST turbulence model
Richard Renaud
Richard Renaud is on a distinguished road
I have a general question about when it is beneficial to use an SST turbulence model.
I've been reading up on turbulence lately. Prior to this recent study, I had a habit of using the SST turbulence model without checking the y-plus of my grid. For example, I used SST when modelling a cylindrical feed well with a tangential inlet pipe that contains baffles. Since there are baffles perpendicular to the flow, separation is likely to occur and I thought that SST would be a good choice to model this. However, I checked my mesh and my y-plus is on the order of 100!
I am wondering, as a general question, does SST offer any advantages over a standard k-ε model when the boundary layer is not well refined. If it is computationally infeasible for me to refine the boundary layer with a y+ of 1, would you recommend that I stick with the SST model anyways? Or does the SST model offer no benefits over a k-ε model when the mesh refinement in the boundary layer is insufficient?
Thanks,
Richard Renaud
Richard Renaud is offline   Reply With Quote
Old   December 19, 2015, 05:13
Syed Aaquib Hazari
hazari.aaquib is on a distinguished road
Dear Richard,
If you're planning to use a grid with a large yplus of the order of 100 I suggest that you should use k-e model.
Only if your yplus is less than 2 (it can extend till 4) you should use the SST or k-w model.
At a wall gradients are steep and basically the SST and k-w model directly solve the equations at the grid cells. While k-e uses wall functions to solve the gradients hence less computationally expensive.
Furthermore, SST is a combination of k-w and k-e.
Good luck!
hazari.aaquib is offline   Reply With Quote
Hoz to fix Y+ dependence on inlet Mach number? SST turbulence model LuReym CFX 5 January 20, 2015 17:28
boundary and initial condition for SST k-omga turbulence model mb.pejvak Main CFD Forum 3 May 1, 2012 21:06
General question: turbulence and laminar models fluentmonkey Main CFD Forum 12 March 17, 2011 15:47
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 14:57
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
