Home > Forums > General Forums > CFD Freelancers
OpenFoam wave2Foam installation on Ubuntu
Old   November 19, 2015, 09:43
Default OpenFoam wave2Foam installation on Ubuntu
Joseph D.
jdttl is on a distinguished road
Hi, I am a newbie using OpenFoam and about to create a simulation of oceanic wave. Through my researches, I found out to use the wave2Foam library. I followed the installation steps stated in this link https://openfoamwiki.net/index.php/Contrib/waves2Foam however as mentioned there might come an error when "Allwmake" file is run. As I run the said file I encountered this error:
FATAL ERROR.
The directory path /home/user/OpenFOAM/user-3.0.0/applications/utilities/waves2Foam does not exist.
Correct the path in bin/bashrc
This means that you should correct the environmental variable $WAVES_DIR
such that it is pointed (in absolute sense) to the path, where waves2Foam
is located.
Please note that once bin/bashrc is created, bin/bashrc.org is only an
inactive file. The latter is also the only of the two files, which is
updated through the SVN-repository.
I know that the error is on the target file path. My problem is what file path should I replace in the "bashrc" file.
1. My OpenFoam installation folder is located at /opt/openfoam30
2. And my working directory for projects is located in /home/user/OpenFoam/user-3.0.0
Any comment will be appreciated.
jdttl is offline   Reply With Quote
Old   June 17, 2016, 07:52
crixman's Avatar
Christian
crixman is on a distinguished road
Hi, check out OLAFOAM (https://openfoamwiki.net/index.php/Contrib/OLAFOAM)
Much easier to install on openfoam3.0!
crixman is offline   Reply With Quote
openfoam
OpenFOAM 2.2.2 source pack installation on Xubuntu 13.10 zordiack OpenFOAM Installation 1 October 26, 2013 14:08
OpenFOAM 1.7 installation on Redhat linux maxims OpenFOAM Installation 2 November 30, 2012 05:29
openfoam installation javad814 OpenFOAM 7 January 27, 2012 12:31
openfoam installation for algeria (dz) abbes OpenFOAM Installation 4 July 18, 2011 20:16
