Home > Forums > General Forums > CFD Freelancers
Ned help with cleaning a code ASAP
Old   November 11, 2015, 02:11
Default Ned help with cleaning a code ASAP
Gbenga
noponusd is on a distinguished road
I am modeling a rice bin drying using a porous media concept
I wrote a UDF to initialize the moisture content using DEFINE_INIT. Then I defined a mass source using DEFINE_SOURCE . I updated the moisture as drying progress (DEFINE_ADJUST). I also wrote UDF for energy source. I compiled my UDF and everything seems ok. But I got Error: received a fatal signal (segmentation fault).
I have been at this juncture for the past 2 weeks and am confused at this time. Please if you have idea on what I can do. I will appreciate it. Thanks
noponusd is offline   Reply With Quote
udf and programming
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 13:30
How to make code run in parallel? cwang5 OpenFOAM Programming & Development 1 May 30, 2011 05:47
Open Source Vs Commercial Software MechE OpenFOAM 28 May 16, 2011 12:02
Error in CFX Solver Leuchte CFX 5 November 6, 2010 07:12
Small 3-D code Zdravko Stojanovic Main CFD Forum 2 July 19, 2010 11:11
