November 5, 2015, 02:53 |
Solid phase trap
Yuri
I use Fluent Multiphase Eulerian-Eulerian model in 2D. On velocity inlet I have gas. In the rectangular body of reactor I have 64mm height filling with particles (particle diameter d=0.09mm). Width of the reactor 20mm. I want to have high velocities (smth. about 10m/s) in the inlet. But if I make 10 m/s gas velocity in the inlet, particles will fly out from the reactor. So I need to make a special outlet boundary condition that won't let particles fly out (gas phase flys out from the reactor and solid phase stays in the reactor). Could You explain me how to make this kind of boundary condition. Thanks. Last edited by Yuri911; November 5, 2015 at 03:55. |
bc particle trap, fluent 14, solid phase filter |
two Phase column simulation | chemeng | OpenFOAM | 3 | August 18, 2010 13:53 |
gas solid phase with chemical reactions | Timonthy | FLUENT | 0 | January 21, 2008 20:41 |
UDF Scalar Code: HT 1 | Greg Perkins | FLUENT | 8 | October 20, 2000 13:40 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 14, 2000 00:03 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 11, 2000 04:43 |
