October 27, 2015, 17:25 |
Named Selection Mesh View
Matthew
Rep Power: 11 |
Hello all,
I am trying to view the mesh on the surface of my wing, which is inside my fluid box. I have named all the faces associated with it under named selection. I would like to view the surface mesh of the wing while hiding the mesh of the fluid so I can do some quality checks and edit as I see fit. However, everytime I go to highlight it under named selections, the mesh disappears. When I toggle "show mesh" it shows the mesh of all named selections and I cant see the surface of my wing. (See attached photos.) Any reason why this is happening? I am using ANSYS v16 and am doing my meshing in the workbench. |
October 27, 2015, 20:23 |
freelancer.cae
Rep Power: 12 |
send me your model at freelancer.cfd@gmail.com and I will fix it and send you back
October 28, 2015, 01:37 |
Matthew
Rep Power: 11 |
As much as I appreciate the reply, I would rather not send an email to somebody I do not know.
Is there no suggestions you can offer me through this thread? |
October 28, 2015, 09:56 |
Rep Power: 13 |
You can use cut planes
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 08:05 |
Meshing Issue with Named Selection | DamR | FLUENT | 0 | January 1, 2015 04:00 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
