Home > Forums > General Forums > CFD Freelancers
Freelancer Job: Project 2D shock tube
Old   March 8, 2015, 17:53
Default Freelancer Job: Project 2D shock tube
Benjamin Ports
cofferhugger is on a distinguished road
Hi all
Freelancer Job
I am willing to spend $500 (thru Paypal) to have one you to code an entire Matlab computer codes to solve 2-D inviscid compressible flow problem. However the Code must be validated and checked for accuracy of your numerical solutions, such as analytical solutions, experimental results, or published CFD, etc. (will be provided) results by other people. Also you need to compute the same problem using at least two sets of grids to evaluate the numerical accuracy of your results.
I will forward images of problem if any one is interested. Thanks
cofferhugger is offline   Reply With Quote
Old   March 10, 2015, 10:53
Default Freelancing
Manoj
manojkv is on a distinguished road
Send a message via Yahoo to manojkv
I can give it a try as i have prior knowledge in MATLAB. Please email your problem to nimblesouth@gmail.com
manojkv is offline   Reply With Quote
Old   March 19, 2015, 06:44
Subramanyam Natarajan
subramanyamn is on a distinguished road
Hi cofferhugger,
Please send me the pre-requisites on sn@chmod.in.
I have a masters degree in compressible flow and performed projects in conceptual modelling of gas turbines in Matlab. I might be able to help you.
Regards,
Subu
subramanyamn is offline   Reply With Quote
Old   March 30, 2015, 13:21
Default matlab code for 2D inviscid compressible flow
Sourabh Jain
SourabhJain is on a distinguished road
Originally Posted by cofferhugger View Post
Hi all
Freelancer Job
I am CFD developer with experience on 3D turbulent N-S solver. I can write code for you. Do you have some fixed geometry. Which numerical scheme you would prefer. If you can give me flow conditions and geometry, I can better comment on efforts required. If it is shock tube and you just need to model motion of shock, expansion fan and contact discontinuity, let me know.
Regards
Sourabh
SourabhJain is offline   Reply With Quote
Old   April 29, 2015, 10:34
Matt
fluid23 is on a distinguished road
This can be solved without CFD. Why do you need a navier-stokes solution? This is a classical method of characteristics problem.
I had this very assignment (almost verbatim) in compressible aerodynamics in grad school. Surely you aren't paying someone to do your homework for you, right? $500 is way too much for a simple problem like this. Can be done in an afternoon.
fluid23 is offline   Reply With Quote
Old   July 5, 2015, 13:59
Default Freelancing
hamid reza
hambo is on a distinguished road
I can do it with godunov method using hllc rieman solver (second order muscl)
and the results will be compared with 1d and 2d shocktubes and generally any problem from this paper
Comparison of Several Difference Schemes on 1D and 2D Test Problems for the Euler Equations
gomboli1 at gmail.com
hambo is offline   Reply With Quote
Old   July 15, 2015, 17:20
Jammy
jammypramod1 is on a distinguished road
I can do Riemann solver on both structured grids and unstructured grids using FVM and FDM. I have more than 7 years experience in Code development for supersonic/ hypersonic flows
jammypramod1 is offline   Reply With Quote
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 2 May 20, 2016 03:10
Modelling a shock tube in ANSYS Fluent crustaccione FLUENT 1 June 16, 2014 14:16
Modelling Shock Tube with Venting RCBlast Main CFD Forum 1 December 17, 2012 10:40
rhoCentralFoam not reflecting shock in Shock Tube? Astaria OpenFOAM Running, Solving & CFD 5 March 4, 2012 04:07
Shock tube problem AB Siemens 1 November 9, 2004 01:25
