Home > Forums > Software User Forums > AVL FIRE
How to import .STL file into AVL fire ?
Old   March 27, 2023, 13:09
Default How to import .STL file into AVL fire ?
Gxi
uudijrh is on a distinguished road
Hello ~
I have just started using this.
I have built the model using Solidworks and saved it in .STL format. I know that AVL FAME is required for mesh generation, but it provides three options, and none of them recognize .STL files. Am I missing a step?
My ultimate goal is to use AVL FIRE to simulate the processing of an SCR system. I hope to get some ideas or someone who can tell me the general process to complete it, as this software is quite difficult to learn.
Thank you in advance for your help .
Also, if anyone needs some official model cases, I can share them with you for free. : )
uudijrh is offline   Reply With Quote
Old   March 28, 2023, 09:40
Default I found it
Gxi
you can't import STL from File. You need to right-click on Meshes, and select "import" from the dropdown menu
avl fire, scr
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
