Home > Forums > Software User Forums > AVL FIRE
H2 gas PFI engine simulation AVL FIRE WF
Old   April 21, 2021, 05:06
Default H2 gas PFI engine simulation AVL FIRE WF
Oiher
H2_Engine is on a distinguished road
I'm trying to simulate a gasoline modified engine, in order to work with H2 gas in AVL FIRE Workflow Manager. The H2 gas is injected in the intake port where the original gasoline inyector was (modified injector). I don't know how to manage it to inject the H2 gas in the simulation tree. I have done some tries with the following methods.
1. Standard gasoline method with spray and wallfilm, changing spray to "gas jet" in "nozzle submodels" and changing initial condition fuel to "Hydrogen". Also fluid properties in spray set to "Hydrogen".
2. Removing the spray and just setting the intake H2 gas flow in the injector boundary condition as a mass flow. H2 only defined in the initial conditions. Air is the only fluid set at fluid properties.
3. Using multhiphase module and setting another fuid, hydrogen, introducing it as a massflow in the injector.
Should I use any module that I'm not using?
May I define a new fluid to use H2 gas?
I would really thank some advice for this task. If someone has worked with a similar gas injected simulation and wants to share the knowledge I would really thank it.
Regards.
H2_Engine is offline   Reply With Quote
avl, egine, gas, hydrogen, injection
Calculation scavenging profile from 2 stroke engine simulation hebe2u. CONVERGE 3 November 7, 2017 17:23
Problem in simulation of toxic gas release billy7590 FLUENT 4 September 14, 2017 15:12
gas properties in AVL Fire Morshed Alam Main CFD Forum 1 August 24, 2010 16:47
AVL fire Exhaust manifold Simulation mohsenfjs Main CFD Forum 0 May 15, 2010 12:51
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
