Home > Forums > Software User Forums > AVL FIRE
Mixing two gases in a valve
Old   July 7, 2015, 13:38
Default Mixing two gases in a valve
lorenrpg is on a distinguished road
Hi everybody,
I would like two know how to mix two different gases, each one with its own inlet, into a valve in a complete mixing. I was told to try with multiphase module but so far i couldn't find a way to resolve this problem.
Thanks in advance.
lorenrpg is offline   Reply With Quote
Old   July 9, 2015, 10:48
Venkatesh V
cfdvenkatesh is on a distinguished road
Originally Posted by lorenrpg View Post
Hi everybody,
Thanks in advance.
You could use Species Transport model to simulate mixing of 2 different gases. If your application is not IC engine related, I would suggest to use General Species Transport.
In the inlets you can specify the mass fractions for the gases you like.
cfdvenkatesh is offline   Reply With Quote
Old   July 16, 2015, 11:32
Thank you so much, but still now i'm not able to to get proper results. I am using the general method to indtroduce the composition of syngas (O2,H2,CH4,CO,CO2,N2) like species and the i set the molar fraction in boundary conditions but it always diverge. I tried changing underrelaxion factor or equations but it is useless.
Thanks.
Old   May 20, 2016, 04:47
Zvonimir
zpetrano is on a distinguished road
Check mesh, then relax a little your time discretisation.
It diverges in which equation? It diverges suddenly or in some time? You can alway put your *.fla file or at least par of it...
BR
Z
zpetrano is offline   Reply With Quote
2D simulation for mixing two non-reacting gases arun.mechie FLUENT 17 August 3, 2016 09:31
rhoReactinBuoyantFoam - Buoyant Mixing of two gases rkc.cfd OpenFOAM Programming & Development 0 July 13, 2014 14:09
Modelling an initially closed valve which a fluid opens siw CFX 1 April 26, 2014 07:32
Gate valve flow simulations... nikesh FloEFD, FloWorks & FloTHERM 5 January 28, 2014 02:31
Floworks: Mixing and thermal analysis of two gases Jay Nelson Main CFD Forum 0 June 14, 2005 19:29
