Home > Forums > Software User Forums > AVL FIRE
Meshing an injection nozzle
Old   October 17, 2014, 10:31
Default Meshing an injection nozzle
sontke is on a distinguished road
Hi
i want to generate a mesh for a diesel injector for the first time.
Therefor i did the tutorial 910 and now i want to borrow the workflow.
They seperate the injector body from the hole in the tutorial, create two volume meshes and connect it again.
The injector mesh is created by rotate an 2D mesh of the injector shape.
For meshing the hole, they paving the outlet and extrude (sweep mode)it along an edge into the injector body.
My problem is that in my geometry has a round at the junction.
Whice method would you recommend for meshing my geometry? Or is possibility to splay my paving?
Thanks for your help
sontke
sontke is offline   Reply With Quote
[GAMBIT] Trouble with meshing Chevron Nozzle piyushvjn ANSYS Meshing & Geometry 0 May 26, 2014 16:14
injection problem Mark New FLUENT 0 August 4, 2013 02:30
point injection Vs Nozzle injection clarify drsrinivasan Main CFD Forum 1 December 18, 2012 13:35
[ICEM] Help in meshing a 2D Nozzle????? harman79 ANSYS Meshing & Geometry 4 November 22, 2009 23:45
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 02:45
