Home > Forums > Software User Forums > AVL FIRE
chamber simulation problem
Old   June 25, 2013, 09:01
Default chamber simulation problem
hamed
hamedhamed is on a distinguished road
Hi everybody,
Im simulating the air flow into a chamber. the dynamic mesh was generated by using ESE chamber modeler in AVL Fire v2011. each time I want to start the simulation from the beginning (370 CA), around 435 CA I have a lot of problems with run. in fact turbulent energy and dissipation rate residuals do not behave well and have a oscillating shape. is there anyway to get rid of it?
regards,
hamed
hamedhamed is offline   Reply With Quote
Old   June 26, 2013, 23:00
Myunghwan Kim
kimmhw is on a distinguished road
Hi hamed,
Frankly, your explanation is too vague.
I guess your problem happens during intake stroke.
In this kind of case, the problem may be very specific to your model.
But in general, I can say you should check the followings.
- check the mesh quality for whole dynamic mesh
==> you can use the cell quality check during dummy run
- boundary condition
==> inlet/outlet condition
- timestep (delta CA and engine speed)
- min. and max. iterations
- relaxation factors
kimmhw is offline   Reply With Quote
Old   June 29, 2013, 08:48
hamed
Thanks for response
I lowered the underrelaxtion factor of turbulent dissipation rate and the simulation resumed.
regards,
Hamed
avl fire
Dynamic mesh simulation (pimpleDyMFoam) problem sidlof OpenFOAM Running, Solving & CFD 6 April 12, 2013 12:24
simulation problem -- convection BC pras FLUENT 4 January 30, 2013 11:41
combustion chamber problem mcnair ANSYS Meshing & Geometry 0 March 16, 2011 13:41
tracer simulation for transient problem. John CFX 0 August 12, 2005 11:37
simulation of incineration problem xinxin Main CFD Forum 1 November 27, 1999 17:34
