Home > Forums > Software User Forums > AVL FIRE
How to add restart file
Old   May 12, 2013, 13:37
Default How to add restart file
hamed
hamedhamed is on a distinguished road
I have already done a simulation in MPI mode. now I want to restart the simulation from specific time step(say 254) in a new project. I can add the SSF file and correspondent restart file by right click on (case) but the simulation would not resume.
please help me.
Hamed
hamedhamed is offline   Reply With Quote
Old   May 14, 2013, 21:24
Myunghwan Kim
kimmhw is on a distinguished road
Hi hamedhamed,
Normally, it should work.
the previous calculation was finished at CA 254?
As you may know, the restart files (rs0, rs1) contain two recent restart files during calculation. On the other hand, the backup file(*.bc_000???) contain the restart file on exact timestep which user defined.
Please check this.
- calculation period of previous calculation
- timestep(crankangle) which two restart files correspondent
- If you have other backup files near CA 254, please try with this.
- in SSF, there is one option "Restart without time information" in Run Mode.
Please check this option was activated or not. It should be deactivated.
kimmhw is offline   Reply With Quote
Old   May 15, 2013, 14:46
hamed
Thanks, kimmhw
avl fire
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 17:46
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 07:43
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
