Home > Forums > Software User Forums > AVL FIRE
How to restart a simulation in MPI mode
Old   April 24, 2013, 17:47
Default How to restart a simulation in MPI mode
hamed
hamedhamed is on a distinguished road
Hi everybody
I have done a simulation in MPI mode with AVL Fire 2011. now I want to restart the simulation from a specific time step. but like single mode, just one processor runs the simulation. how can I fix it?
best regards
Hamed
hamedhamed is offline   Reply With Quote
Old   April 24, 2013, 23:41
Myunghwan Kim
kimmhw is on a distinguished road
Hi hamed,
If I understood correctly, you already calculated using MPI mode.
And then, you want to restart from a specific time step using single(serial) mode.
Right?
Basically, there is no special way.
I hope you are familiar to use the shell.
the command is
cfdwm_solver -solver_vers=v2011 -case=Case -restart=Case.rs0
You have to know which restart file(CaseName.rs0 or CaseName.rs1) or backup file(CaseName.bc_00####) is for the specific time.
Please see the fla file.
If you have some problems to restart, please describe more detail.
- error message
- your application(moving mesh? combustion? aftertreatment? porosity?...)
- others
kimmhw is offline   Reply With Quote
Old   April 25, 2013, 05:56
hamed
thanks for response kimmhw
I already calculated my simulation using MPI mode and I want to restart it using MPI again. but after choosing MPI mode and 8 number of processors, just one processor is working and the rest of processors work with 0 % CPU as shown in task manager.
I do not know how to use all processors for restarting.
Old   April 25, 2013, 22:40
Myunghwan Kim
Hello hamed,
Frankly, it is not easy to understand your problem exactly without your model/log message.
But please try to do as below.
1) if you start the calculation using GUI
there is one advanced option in job setup menu.
Advanced Setting - check "disable file locking "
2) if you start the calculation on shell
Add one argument (-no_file_locking).
cfdwm_solver -solver_version=v2011 -case=CaseName -mpi -cpu=8 -restart=CaseName.rs0 -no_file_locking
Old   April 26, 2013, 14:27
hamed
Thanks kimmhy
"disable file locking" was helpful.
avl fire
Sgimpi pere OpenFOAM 27 September 24, 2011 08:57
Problem with restart henryss STAR-CD 2 October 25, 2009 08:29
Restart Deforming Mesh Calculation Tristan CFX 0 June 22, 2009 19:34
Simulation Time in restart runs Elina CFX 3 January 21, 2009 04:57
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 11:06
