Home > Forums > Software User Forums > Autodesk Simulation CFD
CFdesign problems
Old   June 2, 2009, 08:08
Default CFdesign problems
Carlos
gaussist is on a distinguished road
Hi All,
I am having problems with CFdesign (V9) and PROE (W3). I have a model opened correctly at PROE, but when I tried to open it at CFDesign the CFDesign reports next error:
GEdge::mergeUses - error: couldn't find merge use 2393
Edge Information:
Edge Information:
Invalid Model Detected!
The model has three parts, and I can open them separately, but not the assembly .
Is the CFDesign "more compatible" with other 3D program, such as Catia?. Have you ever had problems like this, opening models in CFDesign?
Basically, I only want to open a .stp file in CFDesign.
Thanks for your help.
gaussist is offline   Reply With Quote
Old   June 30, 2009, 16:09
Ken
zr2driver is on a distinguished road
CFDesign does have issues with ProE data (rather it is converted to a .stp file or not). Make sure you don't have any interferrance in your volumes. This will cause a failure.
zr2driver is offline   Reply With Quote
Old   July 1, 2009, 08:02
Default CFdesign
Jon Wilde
wildejon is on a distinguished road
Hi there,
I work for CFdesign, happy to help if you need it.
Where are you based?
Are you trying to read in a step file or a .asm from ProE? If you go from ProE, there would be no file conversion taking place.
Please feel free to email me if I can help you out, no probs
Jon
wildejon is offline   Reply With Quote
Old   July 8, 2009, 11:41
Default ProE
Matt Hieatt
Matt.Hieatt is on a distinguished road
I work for Mentor Graphics and we produce an excellent piece of CFD software called EFD - this runs inside all popular CAD packages including ProE, there are therefore no conversion problems at all, ever.
It is a very capable solver inside and I can almost guarantee we will be able to solve your problem.
I am not sure where you are based but if you let me know I can point you in the right direction for a local Mentor office. In the meantime our website is http://www.mentor.com/products/mechanical/
Matt.Hieatt is offline   Reply With Quote
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 13:13
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
Problem when launch Cfdesign from ProE Monford Autodesk Simulation CFD 2 September 22, 2008 21:40
Some problems with Star CD Micha Siemens 0 August 6, 2003 14:55
Valve Forces in CFdesign Mike Clapp Main CFD Forum 3 March 8, 2001 15:09
