Determining Stainless Steel Pipe Length for Heat Transfer to Reach 1000°C |
January 25, 2024, 00:28 |
Apo
I'm working on a Uni project where I need to determine the length of a stainless steel pipe that is required to heat a fluid up to 1000°C. The pipe will be placed in an oven that can reach up to 1400°C. The pipe's outer diameter is 6mm, and the inner diameter is 4mm.
I've developed the following heat transfer equation to model the problem (I am not sure if my equation is gonna be shown in the correct way): Code:
\rho \cdot c_p \cdot \frac{d_i^2}{4} \cdot \frac{dT}{dt} = -\left(\frac{\dot{m}}{\pi}\right) \cdot c_p \cdot \frac{dT}{dx} + k \cdot (d_i + 2s) \cdot (T_{\text{Ofen}} - T) Where the parameters are as follows: Density (ρ): 0.311 kg/m³ Heat Capacity (c_p): 1.2149 kJ/kg*K Inner Diameter (d_i): 0.004 m Wall Thickness (s): 0.002 m Mass Flow Rate: 0.000390814 kg/s Heat Transfer Coefficient (k) for the pipe: 12.88723903 W/m²*K Oven Temperature (T_ofen): 1400°C Initial Fluid Temperature (T): 40°C The initial condition is T(t=0, x)=40°C for every position x along the pipe, and the boundary condition at the pipe's end (x=L) is that the temperature gradient (dT/dx) equals zero. Additionally, it can be stated that the fluid is laminar and incompressible. Could anyone advise on how to approach solving this equation to find the required pipe length? I'm considering using OpenFOAM or Autodesk CFD for simulation but am unsure about the best way to incorporate these conditions. Has anyone tackled a similar problem, or could you point me toward relevant tutorials or resources? Thank you for your help! |
cfd - post, fluid dynamics, heat and mass transfer |
Pipe Flow Heat Transfer | Saima | CFX | 5 | January 30, 2011 16:41 |
Heat Transfer in a pipe flow(hot air) | Saima | Main CFD Forum | 0 | January 17, 2011 07:08 |
Flow around pipes - heat transfer coefficient on the wall of pipe | doodek | Main CFD Forum | 2 | November 23, 2009 08:48 |
Conjugate Heat Transfer at a pipe | andoss | CFX | 5 | August 17, 2009 08:54 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
