Home > Forums > Software User Forums > Autodesk Simulation CFD
How do you delete created volumes?
Old   December 4, 2021, 22:46
Default How do you delete created volumes?
Fernando
Ferny is on a distinguished road
I'm somewhat new to CFD. I originally got my analysis solved and decided to run another scenario, and when I went to build the surfaces and fill the voids, I accidentally created extra volumes. How would you delete these unnecessary volumes that were created? I've attempted to hit remove multiple times with no result. I even deleted the scenario only to find my original scenario had also changed. I can't run the simulation because these extra unassigned volumes need to be assigned, even though they are unnecessary. If I could just delete the extra volumes, I could rebuild the surfaces and fill the voids again.
Ferny is offline   Reply With Quote
Old   March 27, 2022, 23:47
Mike Stroup
Mithrandir is on a distinguished road
I am not totally clear on your question.. but in the future, clone your "Design" and make mesh and surfaces mods in a new Design... "Scenarios" are for when you want to change boundary conditions like pressures, velocities etc...
Mithrandir is offline   Reply With Quote
Old   November 5, 2022, 02:51
Mehul Parmar
mehul020892 is on a distinguished road
There is command in Tool name fill use to fill inside volume by creating inlet and outlet surface .
After generating inside volume.in model tab delete extra model which are not required.. then run it is useful.
mehul020892 is offline   Reply With Quote
material, volume
[Gmsh] Boundary layer not created during gmshToFoam for Gmsh4.0 hasankhan OpenFOAM Meshing & Mesh Conversion 1 November 25, 2018 00:29
Non-conformal mesh autimatically created walls - do these act as solid walls? Vestdam FLUENT 1 November 21, 2017 09:07
Negative Volumes Created After Run Start JSped STAR-CCM+ 1 January 18, 2016 13:09
merging faces on a copied volumes kunal FLUENT 0 March 20, 2008 07:50
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
