February 1, 2019, 06:38 |
Combined linear-angular motion (flow driven)
Nat K
Rep Power: 9 |
Hi
I am working on project where a bileaflet valve is moving linearly up and down and should open to a certain angle. When it moves down the pressure should close the valve. I am having trouble getting the valves to open using flow driven motion. The valves open at random times and either one is open and the other is not. This results in unphysical pressures for the device. I have attached a image of the problem. I am using pressure BCs at inlet and outlet, k-epsilon model, intelligent solution. Any advice would help. Last edited by nskelly; March 22, 2019 at 14:14. |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 18:02 |
Boudaries for bouynat driven flow with additional mass flux at inlet | Charon | CFX | 2 | April 27, 2013 09:02 |
suitable boundary condition for scavenging process? | immortality | OpenFOAM Running, Solving & CFD | 3 | January 25, 2013 20:10 |
is there any parallel code for the famous Lid Driven Cavity flow? | gholamghar | Main CFD Forum | 0 | August 1, 2010 02:55 |
solution diverges when linear upwind interpolation scheme is used | subash | OpenFOAM | 0 | May 29, 2010 02:23 |
