June 13, 2018, 06:34 |
Autodesk CFD Duct pressure loss
Kasper H
Hi
We have some duct pressure tests in CFD, and run into a question. Autodesk CFD gives two results in the report. Press: max/min Ptotl: Max / min witch one is the correct value for the static pressure in the system ? when calculatet in other software the (Press: Max) is the closest to the results done by other software. Best Regards Kasper |
June 15, 2018, 09:18 |
Jon Wilde
Rep Power: 9 |
Just use Static Pressure.
In fact, it might be better to use cut planes and the bulk calculator rather than the report as those values could be anywhere... |
Negative Total Pressure Loss Coefficient near the casing in axial compressor | mitra22 | CFX | 1 | December 15, 2017 22:34 |
Secondary Flow with Experimental Measurements of Pressure Loss | gmingardo | CFX | 6 | April 12, 2017 09:58 |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
Analyzing pressure and velocity loss through a zig-zag rectangular duct. | arshbunny | CFX | 1 | January 18, 2015 05:51 |
Total Pressure problem in a duct | anveshkadimi | FLUENT | 0 | July 20, 2012 13:16 |
