Home > Forums > Software User Forums > Autodesk Simulation CFD
Volume FLow Rate as a Result
Old   March 27, 2018, 15:08
Default Volume FLow Rate as a Result
Adrian
adr1an0 is on a distinguished road
for the inlets and outlets, i can chose for the boundary conditions, pressure, velocity, volume flow rate, etc.
but i can not see the volume flow rate as a result.
i have a pipe, and i just want wo know what flow rate i have at the end of the pipe depending on the incoming pressure.
i could calculate the flow rate i i have the avarage speed of the fluid at the end of the pipe. how can i see results as a avarage speed, or flow rate ?
thx.
adr1an0 is offline   Reply With Quote
Old   January 31, 2019, 13:51
Sam Bush
svipdag is on a distinguished road
1. define results plane that intersects with your pipe of interest
2. under the planes stab, use the "bulk calculator" - flow is one of the output options
svipdag is offline   Reply With Quote
volume flow rate for outlet boundry condition and dfine udf for it raminostadi FLUENT 0 December 24, 2016 02:52
Volume flow rate through actuator disk (Tidal turbine) egge24 FLUENT 4 August 12, 2013 16:18
how to calculate the reversed volume flow rate in an certain iso-surface? coolliuyinli FLUENT 2 September 4, 2012 02:33
Volume of Flow Rate (VFR) boundary condition therockyy FLOW-3D 0 May 23, 2011 15:19
