April 14, 2016, 09:11 |
Flow rate reduction analysis
hosein
Hi all,
I am a new autodesk CFD user. and I want to analyze an air tunnel and my goal is to determine the amount of air out let volume. how i have to defined the boundaries? mu boundary setup now is: inlet Volume rate is 900 Cubic meter per hour. out let pressure 0 all the other wall are set to slip. But I received almost the same amount in outlet, but in a practical test I have had an almost 50% reduction in air flow. what would be my mistake or unassign boundary? Tanks for your help. |
December 21, 2016, 08:02 |
Jon Wilde
Rep Power: 10 |
In reality you have less flow exiting than you do entering?
This could only really be true with a high speed compressible study and only with volumetric flow rate, otherwise you really must have the same volume of flow entering and exiting. |
July 29, 2019, 15:16 |
If the water is coming out out of the tip too fast like a tap, then you can increase the pipe size, it wont slow down the volume at all, but itll make it come out in a better flow rate not messing up the media.
flow reduction, volume flow rate |
Target Mass Flow Rate | Nitin | FLUENT | 9 | June 17, 2017 11:30 |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 11:40 |
Mass flow rate boundary condition for continuity equation for oscillating flow | p07ip705 | Main CFD Forum | 0 | February 28, 2013 02:33 |
flow rate decrement | d.h. | Main CFD Forum | 3 | August 6, 2008 06:18 |
Inlet and outlet flow rate | Neser | CFX | 1 | March 2, 2004 17:02 |
