Home > Forums > Software User Forums > Autodesk Simulation CFD
Heat transfer in a pipe flow
Old   March 19, 2016, 13:18
Default Heat transfer in a pipe flow
Prabhu Prakash
daijo is on a distinguished road
Dear all,
kindly help me with the following problem.
Pipe ID = 300 mm
Pipe OD = 320 mm
Pipe Length = 15 m
Fluid = steam
Pipe material AISI 1330 (density = 7870 Kg/m^3 | Sp. heat = 472 J/Kg K | Th. conductivity = 51.9 W/m K)
Available Boundary Conditions at Inlet are:
Mass flow = 90 tons/hr
Velocity = 17m/s
Pressure = 64 Bar
Temperature = 480 Celsius
Assumed film co-efficient = 14.5 W/m^2 K
Tool used: Autodesk CF Design 2013 & 2015
I have solved the problem, but the outputs are not as expected.
What kind of settings to be followed throughout.
Can you kindly help me in solving the problem.
daijo is offline   Reply With Quote
cfd analysis, heat transfer, pipe flow
Reverse Flow In NanoFluid Based Double Pipe Counter Flow Heat Exchanger nabidinhomessi FLUENT 0 November 15, 2015 10:33
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
[ANSYS Meshing] heat transfer through a pipe cfdjunkie ANSYS Meshing & Geometry 3 September 18, 2012 22:53
Conjugate heat transfer in reacting flow ali_1364reza OpenFOAM 1 May 30, 2012 15:15
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
