October 21, 2013, 12:08 |
Solidworks 2010 models to CFDesign v9
Dan
Hello all,
I wonder if someone could advise a new user to CFDesign. I am trying to transfer a SW assembly 2010 over to CFDesign V9, previously I used V8, and the model transferred fairly easily, from memory there was a button on SW that opened the new file automatically. When I save the model as a parasolid it becomes a collection of surfaces rather than a collection of solid entities. Is it possible to transfer the model as a solid, so I can select which parts are fluids and which are solids? Is there a website that you can recommend that would show a newish user how to do this? Thanks in advance, Dan |
October 22, 2013, 14:18 |
Apolo
Rep Power: 17 |
dan,
There would be a button in SWx for the versions of SWx that CFdesign V9 supports. V9 ended in ~2008 such that it would not have the launcher for SWx2010. You would either need to update to a newer version (Currently as Simulation CFD 2014 and notably improved over v9) or you will have to continue using parasolids. As far as the parasolids saving only surfaces, you might look in to the parasolid options within SWx to see what is selected and how the geometry is being built |
Importing Rhinoceros 3d model to SolidWorks | george85 | FloEFD, FloWorks & FloTHERM | 21 | March 5, 2014 05:19 |
importing from solidworks 2010 to ANSYS v.13 | Aly | ANSYS | 0 | August 26, 2011 19:35 |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 02:20 |
Error in importing geometry from solidworks 2010 to Gambit 2.4.6 | ck3 | FLUENT | 4 | September 9, 2010 08:59 |
CFDesign V10 and Solidworks 2010 | sonodelirii | Autodesk Simulation CFD | 1 | August 25, 2010 20:11 |
