Home > Forums > Software User Forums > Autodesk Simulation CFD
cfdesign links to abaqus(flow-structure analysis)
Old   October 26, 2006, 21:18
Default cfdesign links to abaqus(flow-structure analysis)
rick
Recently, I want to do some structure analysis with pressure load. Cfdesign can map it's result to abaqus. I tried it but some problems happened. First, I try single component and it is ok to map the result. Then I try two components at the same time, but it can't map accurate result to abaqus. Does anyone try to do it? Anybody knows what happened? Thanks
Old   October 31, 2006, 05:23
Default Re: cfdesign links to abaqus(flow-structure analys
m.suresh kumar
Can you send your _s file to me? CFDesign is the good tool for mapping the CFD results into abaqus. Since CFDesign is the software using FE method against most common softwares using FV method, it will be viable for mapping into structural analysis.
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
Analysis for bake-out of a structure anna_67 CFX 2 July 8, 2009 19:32
New ANSYS forum structure, what do you think? Peter CFX 5 February 4, 2009 12:59
Short Course: Computational Thermal Analysis Dean S. Schrage Main CFD Forum 11 September 27, 2000 18:46
Is CFD Science or Art ? John C. Chien Main CFD Forum 36 October 5, 1999 13:58
