Home > Forums > Software User Forums > Autodesk Simulation CFD
Compressible flow Simulation in CFDesign
Old   August 27, 2012, 02:56
Default Compressible flow Simulation in CFDesign
krishna_msrit is on a distinguished road
Trying to solve a high subsonic compressible flow through a butterfly valve.
Having lot of issues with convergence. Typical problems like
1. High unrealistic velocities in enhancement layers.
2. Unrealistic high pressures.
3. High velocity at outlet.
settings used are :
Inlet: velocity and static pressure
Outlet: unknown
Turbulence Model - ke
Please advise if any settings to be enabled or the process to achieve good convergence for compressible flows in CFDesign
Thanks
krishna_msrit is offline   Reply With Quote
Old   September 10, 2012, 00:00
jwdenhartog is on a distinguished road
Definitely check out the suggested setups for internal compressible flow in the Simulation CFD Wikihelp:
http://wikihelp.autodesk.com/Simulat...62-Internal762
The most common setup approach for these problems is Total Pressure >0 at inlet and Static Pressure = 0 at the outlet so you might want to start there. If you need to use the velocity and pressure at the inlet with unknown at the outlet like you described, make sure the pressure is a total pressure boundary condition.
Beyond that, mesh refinement will probably be helpful. You might also try some solver relaxation in the Solution Controls dialog.
You can log a support case here if needed:
http://subscription.autodesk.com/sp/...74&id=11607975
jwdenhartog is offline   Reply With Quote
compressible flow, subsonic flow
Differences and functions of Solidworks Simulation and Solidworks Flow Simulation? alpharays Main CFD Forum 0 April 19, 2012 04:13
how to set BC for compressible flow target mass flow rate foolboy007 FLUENT 1 April 4, 2012 04:24
CFDesign V11 -- Reverse flow at outlet maruthiv Autodesk Simulation CFD 1 June 17, 2011 10:38
Unsteady simulation of flow past wheel Tom FLUENT 8 January 18, 2006 11:54
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 18:23
