Bruce
Rep Power: 0 ![]() |
Hi all,
I'm trying to simulate the parabolic phenomena of a spinning fluid (the phenomena is described in rotate-body.jpg) I'm using Autodesk Simulation CFD and trying to simulate the simplest configuration as possible. the rotating part is a cylinder with inner cone (pic1) i created another part, which is the initial water level inside the cone (also in pic1). I'm having difficulties defining the rotating part and water area. could anybody help me defining any solution the solver can handle? i would really want to see the phenomena as demonstrated in "rotate-body.jpg" Thanks in advance, nyg |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
[ANSYS Meshing] How to include an internal surface in fluid vol | jwillie2000 | ANSYS Meshing & Geometry | 0 | May 4, 2012 11:10 |
Questions of fluid pairs | fjalil | CFX | 1 | June 10, 2009 17:36 |
Fluid pairs | fjalil | Main CFD Forum | 0 | June 10, 2009 13:47 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
