April 16, 2012, 14:29 |
mesh - file from stand alone project
Stephan Langenberg
Rep Power: 15 |
Hallo,
I've got a .cas- and a .dat - file. In order to check the quality of the mesh I want to create a meshfile out of this "stand - alone - project" (Fluent Analysis System in the toolbox) Does anyone know how to get the mesh (.msh) from an existing Case or Data? greetings, Jim |
April 16, 2012, 14:46 |
Ghazlani M. Ali
Rep Power: 29 |
i never had the occasion to try but in Fluent if you click on file>write>boundary mesh, it will generate a .msh file for you. May be that's what you want let me know if it works
April 16, 2012, 18:48 |
Stephan Langenberg
Rep Power: 15 |
That was the first thing I did
I tried it and noticed that the boundary mesh and the "normal mesh" are nt the same. If I have a normal mesh (for example in the component setting) I can link it to the finite Element Modeler and check the settings. (skewness, aspect ratio etc.) I guess the finite Element Modeler should be linked to the "stand - alone -project" similar to the coponent construction, but I don't get it. greetings, Jim |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 12:44 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 18:18 |
1.7.x Environment Variables on Linux 10.04 | rasma | OpenFOAM Installation | 9 | July 30, 2010 05:43 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
