April 8, 2012, 04:27 |
error in opening fluent in ansys workbench
tmeysam92
Rep Power: 15 |
hi guys,
i installed ansys 14. i can work with fluid flow(fluent) in analysis system. but when i open fluent (in component system) it gives this error. Welcome to ANSYS FLUENT 14.0.0 Copyright 2011 ANSYS, Inc.. All Rights Reserved. Unauthorized use, distribution or duplication is prohibited. This product is subject to U.S. laws governing export and re-export. For full Legal Notice, see documentation. Build Time: Oct 25 2011 11:42:28 Build Id: 10398 Loading "C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0\lib \fl_s1119.dmp" Done. Cannot find license file. The license files (or license server system network addresses) attempted are listed below. Use LM_LICENSE_FILE to use a different license file, or contact your software provider for a license file. Feature: fluent Filename: C:\PROGRA~1\ANSYSI~1\v140\fluent\license tx86\..\license.dat License path: C:\PROGRA~1\ANSYSI~1\v140\fluent\license tx86\..\license.dat FLEXnet Licensing error:-1,359. System Error: 2 "No such file or directory" For further information, refer to the FLEXnet Licensing End User Guide, available at "www.macrovision.com". ANSYS LICENSE MANAGER ERROR:Failover feature 'ANSYS FLUENT Solver' specified in license preferences is not available. Request name acfd_fluent_solver does not exist in the licensing pool. The desired vendor daemon is down. Check the lmgrd log file, or try lmreread. Feature: acfd_fluent_solver Vendor:Host: ADELANTEH-PC License path: 1055@ADELANTEH-PC; FLEXnet Licensing error:-97,121 For further information, refer to the FLEXnet Licensing documentation, available at "www.acresso.com". Hit return to exit. what should i do??? please help me. thanks in advance. |
August 3, 2012, 01:05 |
Tenglong Cong
Rep Power: 15 |
anybody can help?
March 12, 2013, 03:11 |
Rep Power: 17 |
Hi, have you solved this problem yet?
Cause I got the same problem right now! |
March 12, 2013, 07:10 |
Stuart Buckingham
Rep Power: 26 |
Nguyen, you should contact your system administrator to get the details of your license server, or the license file.
Stu |
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 10:23 |
Link faces meshes for periodic BC with ANSYS WORKBENCH | mawi01 | ANSYS Meshing & Geometry | 5 | March 13, 2016 14:10 |
fluent and her difference to Ansys fluent? | heidar | FLUENT | 0 | February 15, 2012 07:55 |
[GAMBIT] 3.5 years overtake by Ansys: Where are the enhancements in grid generation | Volker P. | ANSYS Meshing & Geometry | 22 | January 17, 2012 18:27 |
Time to open Fluent from Workbench | ResH | FLUENT | 0 | September 30, 2010 03:11 |
