Residuals criteria
Old   March 25, 2012, 10:23
Default Residuals criteria
Robert
Kwiaci is on a distinguished road
I want to ask what absolute criteria for residuals do you use in yours analyses? What value do you use?
For example - is 10e-12 a satisfactory convergence absolute criteria? Is there any theory providing the guidance in this manner?
Kwiaci is offline   Reply With Quote
Old   March 26, 2012, 05:04
Max
murx is on a distinguished road
The convergence criteria depends on your simulation and on your objective.
You should probably check how the convergence criterion affects the parameter you are interested in. Start with a weak convergence criterion, e.g. 10e-4 and have a look at the solution parameter of interest. Then do more simulations and lower the convergence criterion step by step. When your solution does not change significantly anymore, you have reached your satisfactory convergence criterion.
To my knowledge, 10e-12 for RMS or max residual is generally a pretty strict convergence criterion.
murx is offline   Reply With Quote
[Tutorials] Tutorial of how to plot residuals ! wolle1982 OpenFOAM Community Contributions 172 December 6, 2024 07:20
under-relaxation factors -> level of residuals Zigainer FLUENT 19 July 21, 2017 17:53
what to monitor besides residuals? franzdrs FLUENT 5 March 21, 2013 04:59
How can I set the converge criteria properly? Alina FLUENT 3 September 7, 2007 17:55
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 06:45
