Mesh Seeds in ANSYS WorkBench Meshing
Old   March 12, 2012, 13:45
Default Mesh Seeds in ANSYS WorkBench Meshing
Sheridan McPheeters
smcp is on a distinguished road
Hello all,
I am having some trouble sorting out a way to run a sort of parametric mesh routine in WorkBench. Routine is a little misleading - I'm not trying to run a script. Basically, I have an aero/fluid-solid with a modular region, so I would like to mesh the entire body (not including the modular region) a single time, and then be able to mesh the variable module such that it conforms to the original mesh. This would be a very similar operation to using mesh seeds in ICEM.
I have considered using the skin command in FE Modeler, but this just produces surfaces, not an actual mesh seed. Can anyone think of a solution? Is it even possible in the WB framework?
Thank you very much for your help, in advance.
Sincerely,
Sheridan
P.S. Windows 32 bit platform
smcp is offline   Reply With Quote
Old   March 12, 2012, 14:16
Sheridan McPheeters
Sorry... Also forgot to mention version is 14.0
- Sheridan
ansys, meshing 3d, workbench
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
[ANSYS Meshing] Ansys meshing with extended meshing jsm ANSYS Meshing & Geometry 6 January 10, 2011 13:09
2D mesh in ANSYS 10.0 Workbench Frank Peters CFX 4 May 18, 2006 05:36
