Best Way to Model Fan in Open Air
Old   February 13, 2012, 13:38
Default Best Way to Model Fan in Open Air
Orb
Orb is on a distinguished road
What is the best way to model a fan inside of an open ended tube to air? I want the fan to do all the work to the fluid (e.g. no inlet/outlet conditions). Unless there is a way to apply boundary conditions so that they are essentially initial conditions. Or do I do this with transient analysis?
Orb is offline   Reply With Quote
Old   February 14, 2012, 14:33
Emre G
emreg is on a distinguished road
you have to use MRF. steady is enough.
make ur inlet B.C = pressure inlet..
and outler BC=pressure outlet...
then give atm pressure to both of them.
emreg is offline   Reply With Quote
Old   February 14, 2012, 15:59
Orb
Thanks for your post. You are saying make the enclosure large enough to where the boundary conditions dont affect the fluid around the fan? Can you do this without boundary conditions? Similar to mixing in a tank?
Old   March 1, 2012, 10:35
Default momentum source
krisshoe is on a distinguished road
To model a fan in a tube, you can make your tube a separate fluid zone, and define a momentum source within this zone. You can adjust the magnitude of the momentum source to obtain the flow rate that you desire. Alternatively, you can define an surface with a pressure jump condition, and adjust the pressure drop to match the flow you want.
krisshoe is offline   Reply With Quote
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 09:24
LES model (oneEqEddy), air entrainment predictions N. A. OpenFOAM 1 November 7, 2010 14:17
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Fan heater model: what turbulence source to use? andy20 Main CFD Forum 0 March 2, 2008 13:46
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 02:40
