Problem with Newton's cradle Ansys WB 13.0
Old   January 5, 2012, 10:35
Default Problem with Newton's cradle Ansys WB 13.0
jackmarrow is on a distinguished road
Hi!
I'm going a school project where I'm supposed to create a Newton cradle i ANSYS Workbench 13.0. My problem is that i can't even get it to swing. See attachment for geometry and settings.
It consist of a 2-D surface model, a string as the "line" 4 x 80 mm with a vertex, and a circle D = 30 mm, with shared nodes.
The vertex of the line is attached with a remote displacement that is zero in X- and Y-direction and free rotation about Z. A Standard earth gravitation is also applied.
The only thing that happens is that it moves like 5 degrees (12 mm deformation) I have tried to change the time interval and a lot of other stuff. ATM it is a static structure, Does it need to be transient? Tried that too but can't make it work either.
jackmarrow is offline   Reply With Quote
2-d, ansys, cradle, newton, workbench
Problem with modelling contact in ansys fluent 12.1 mak86 FLUENT 16 August 27, 2019 10:07
problem with Transient Thermal Ansys simox 2 ANSYS 0 January 11, 2011 15:49
Ansys mesh import problem sys999 ANSYS Meshing & Geometry 4 January 4, 2011 12:54
ansys problem ENGRTAHIR Main CFD Forum 0 May 11, 2010 17:29
problem in import ANSYS mesh sheryl CFX 2 April 30, 2005 22:30
