Ansys 13 license file problem [ linux suse 11.4 ]
Old   October 31, 2011, 15:19
Default Ansys 13 license file problem [ linux suse 11.4 ]
skrzatchlewny is on a distinguished road
I have installed ANSYS 13 on suse, but I cannot load license file. When i try to load the license I get "invalid license file: the hostid of this machine does not match the hostid in the license file". The license is created by AP_13Calc.exe and it has correct structure [host name and mac adress are ok]. Does anybody know how to fix it?
Thank you,
skrzat
skrzatchlewny is offline   Reply With Quote
Old   November 1, 2011, 13:38
alquimista is on a distinguished road
Can you see the FLEXID when you click "Display the License Server Machine Hostid" in the "anslic_admin" utiliy?. If not (probably) you must install the "lsb" package. As referenced in the Installation and Licensing Documentation Pag. 61.
It works for me.
Last edited by alquimista; November 2, 2011 at 07:41. Reason: Error in the name of the package
alquimista is offline   Reply With Quote
Old   November 2, 2011, 07:45
I have edited my previous reply because of an error. I hope it is useful to you.
Old   November 3, 2011, 01:01
It solved the problem. Thank you!
Old   February 17, 2012, 06:49
Talking This method is correct!
XuDongNa
supersoldier is on a distinguished road
Send a message via ICQ to supersoldier
I also have this problem ,I have installed this software in Ubuntu many times ,it tells me "Invalid license file:The hostid of this machine does not match the hostid in the license file" This method is ok , you need install lsb!
supersoldier is offline   Reply With Quote
Old   July 11, 2012, 07:37
Haris Hameed
harishameed33 is on a distinguished road
what is lsb package. i am using CentOS and getting the same error
harishameed33 is offline   Reply With Quote
Old   July 11, 2012, 07:55
"TheLinux Standard Base (LSB) is a joint project by several Linux distributions under the organizational structure of the Linux Foundation to standardize the software system structure, including the filesystem hierarchy, used with Linuxoperating system. The LSB is based on the POSIXspecification, the Single UNIX Specification, and several other open standards, but extends them in certain areas."
For CentOS I think that you need install redhat-lsb:
yum install redhat-lsb
Old   July 11, 2012, 08:11
Haris Hameed
i have installed the lsb package but still i am not getting the FLEXid
Old   December 11, 2012, 08:56
Shengli Xu
field is on a distinguished road
CentOs 6.3 x86_64 is used. With ansys12.1 and 14, both tell "Invalid license file:The hostid of this machine does not match the hostid in the license file". With ansys12.1, "display hostid" is blank. With ansys14, "display hostid" is 000000000000.
How to solve it?
field is offline   Reply With Quote
Old   December 11, 2012, 10:27
Haris Hameed
I also had the same problem problem when installing ansys on CentOS 6.2.... i tried alot but in the end gave up. you can try to install it on ubuntu or may be purchased license will solve ur problem...if you found any solution for centOS kindly share with me also....
Old   January 10, 2013, 05:38
Default A quick question...
  #11
Morteza Teymoori
Biomech_eng is on a distinguished road
hello everybody
i am so new in this field ... I was wondering what are the pros and cons of using ansys in Linux compared to windows?
i would be glad to know...because I want to continue learning advanced topics with the better one.
thanks
Biomech_eng is offline   Reply With Quote
Old   March 16, 2014, 16:51
Chandrasekhar
chandrasekhar is on a distinguished road
Hi
i have just installed Ansys on Linux and i was getting the same error with the license file(that the host name is not the same as the machine). i downloaded lsb. i tried using the license file again but the same error occurred. i would like to know what i have to do next to install the license file on Linux. Any help on this would be most appreciated. Many thanks for replying.
with regards
chandrasekhar is offline   Reply With Quote
Old   March 18, 2014, 09:10
Talking add host
  #13
XuDongNa
I think you should edit the file /etc/hosts and add "127.0.0.1 yourhostname" in a new line! Good Luck!
Originally Posted by chandrasekhar View Post
Hi
with regards
ansys 13, license error, linux, suse
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 12:47
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 05:26
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
gcc and executable file from Mac to Linux simone Marras Main CFD Forum 0 April 8, 2007 16:49
