help on Immersed Solid approach
Old   October 26, 2011, 11:24
Default help on Immersed Solid approach
Tamal
anori is on a distinguished road
Hello everyone,
I am new to Ansys and I am doing a research project with my professor to study the Immersed Solid approach. I have been searching extensively for tutorials, guides, suggestions, etc. but I find it not to be that easy.
I am modeling two cylindrical discs (no teeth; pure cylinder) which are rotating counter-directional of each other in a fluid domain. A rotation is applied to the disks which are immersed solids. There is a gap of 5mm space between. My objective is to see the pressure and velocity change of the fluid.
The problem I am coming up with is a unreal pressure difference betweeen max and min.
I suspect is it due to the meshing at the 5mm wide gap. Since IS technique is not quite reliable for boundary layer analysis (correct me if I am wrong) I suspect the 5mm gap zill overlap the boundaries of both disks. The only solution I see woul be to make the meshing at the gap very very fine.
Thanks
anori is offline   Reply With Quote
Old   October 26, 2011, 12:00
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Looks like a converging diverging nozzle type effect (forced type flow)
Far is offline   Reply With Quote
Old   October 27, 2011, 10:42
Tamal
Is this a problem for IS approach?
Also, woul someone kindly explain momentum scale factor for me. From what I read I suspect it might a variable I should adjust but I don't completely understand what it does exactly.
Thanks
Old   October 27, 2011, 11:44
Far
Sijal
Well I ain't expert of IM method, so can not say further.
Old   October 27, 2011, 11:50
Far
Sijal
http://www.edr.no/blogg/ansys_blogge...mmersed_solids
This might be helpful, if you didn't come across this already
Old   October 28, 2011, 09:40
Tamal
EDIT, nevermind.
Thanks
Old   May 25, 2012, 07:02
belgacem
belgacem is on a distinguished road
Hi Friends
I am also studying immersed boundary method and and try to simulate a block falling in the water. I am using "immersed solid" then rigid body 6DOF and I let it fall freely but it can't stoped in the bottom where the velocity must be zero. I give a density to the block and i let it fall freely under gravity. Noted that the rigid body is defined as an immersed solid. i have specified a stationary coordinate frame that has its origin at the center of mass of the physical rigid body. Another fixed coordinate frame was specified related to the water at rest.
What can I do to stopped the rigid body in the bottom where the potentiel energy must be zero?
thank you!
belgacem is offline   Reply With Quote
question about immersed solid in CFX 12.0 Anny CFX 11 October 4, 2016 05:22
Question about immersed solid method in CFX spwater CFX 6 May 24, 2012 14:05
Immersed Solid no flow! exocubedesign CFX 3 May 25, 2010 02:57
Rigid Body State Variables in Solid Immersed Simulation Hamidreza CFX 1 October 19, 2009 07:14
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
