Effect of the time step size on the calculatino result
Old   October 25, 2011, 07:42
Default Effect of the time step size on the calculatino result
norman_bates is on a distinguished road
Hello everyone,
i´m quite a rookie at fluent and after spending a lot of hours trying to find a solution to my problem i thought i could share iht with you. The problem i´m trying to solve is just a simple transient heat transfer problem. I define one part of a sphere to be warmer than the rest and watch the temperature to disperse.
When i now solve this for the same time period but using different time steps (i.e. i divide the same time span into a different amount of steps) the result varies pretty strong. I have 2 question:
1. The reason for the difference should be the dependency between the time step size and the element size right? This would mean, that if my time steps are smaller than the time it takes for the temperature to travel through one finite element the result should always be the same?
2. Is there an automated way within fluent to select the appropriate time step?
Thanks a lot in advance
norman_bates is offline   Reply With Quote
Old   October 29, 2011, 04:53
mohammad
mohammadkm is on a distinguished road
Dear norman
1)You should decrease the time step until the difference between the restults become independent of time step.
2)in implicit model there is no criteria for time step
mohammadkm is offline   Reply With Quote
Old   December 15, 2011, 06:03
Default simple logic
karthickeyan
karthickeyan is on a distinguished road
Send a message via Skype™ to karthickeyan
time step is element size/velocity.which should not be equal to 1
Originally Posted by norman_bates View Post
Hello everyone,
karthickeyan is offline   Reply With Quote
accuracy, element size, time step
Time step size, number of time steps and max iterations per time step guido_88 FLUENT 4 August 30, 2012 15:49
Time step, Number of time step, Maxximum Iterations per time step sandisk FLUENT 0 July 18, 2011 03:57
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 05:35
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
