[CFX,ICEM] Simulation of wing / airfoil profile - pyramid elements, angle of attack
Old   October 25, 2011, 05:37
Default [CFX,ICEM] Simulation of wing / airfoil profile - pyramid elements, angle of attack
Jonas_mm is on a distinguished road
I'm quite new to cfd simulation with ANSYS cfx and icem. I'm trying to simulate some wing profiles under different angles of attack to find out the lift and drag. The goal is to create a wing for a formula car with estimated corner speeds of ~40km/h.
I already got some results but I am wondering whether I am getting correct reults or I can speed up my work.
what i do:
- extrude profile in catia, set the angle of attack, create a box around it, import it as *.igs in icem
- create octree mesh, create delaunay mesh, generate prsim layer on wing surface
-solve it with cfx, 40 km/h inlet velocity
questions:
- is my procedure correct?
- i always get a row of pyramid elements at the edge of the wing, where the two prism layers meet. is there a quick way to get rid of it? will it affect my results?
- is there a better way to simulate different angles of attack then rotating it in catia an generate a new mesh
thank you for your answers
Jonas
Jonas_mm is offline   Reply With Quote
Old   November 1, 2011, 08:40
can anyone help?
thanks
Old   November 4, 2011, 04:26
Matthias Voß
mvoss is on a distinguished road
hey,
depending on your farfield configuration you could also think about instead of changing the geometry just changing the inlet_vector via CEL-Expressions from run to run. OR use the parameter options (e.g. DOE) and the scripting within ICEM.
neewbie
mvoss is offline   Reply With Quote
airfoil, pyramid, wing
Forward swept wing simulation abid Siemens 1 June 16, 2012 14:26
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) Josh CFX 9 August 18, 2009 12:31
Transient Angle of Attack Simulation Not Displaying in Post Josh CFX 35 August 5, 2009 10:16
Airfoil simulation using moving wall Alejandro Fidelity CFD 9 November 4, 2008 03:00
Airfoil simulation in High Angles of Attack Yasser Nabavi FLUENT 0 April 21, 2006 18:28
