Creating & Meshing Geometry in GAMBIT
Old   October 24, 2011, 04:36
Default Creating & Meshing Geometry in GAMBIT
Taiwo
Taiwo_Oni is on a distinguished road
Hi everyone,
I am working on a test-section. It has a twisted tape inserted in a circular tube. To be specific, the twisted tape is made by making some rectangular cuts on the surface (not edge) of a tape strip and then twisted by 270 degrees.
I earnestly want you to give me a detailed description of how I will create & mesh the test-section using GAMBIT.
Thanks for your anticipated assistance.
Taiwo_Oni is offline   Reply With Quote
Old   October 25, 2011, 04:58
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Use sweep face with twist option.
http://my.fit.edu/itresources/manual...eom_volm_sweep
A picture is always welcomed
PS: There is a subforum, dedicated to meshing tools:
http://www.cfd-online.com/Forums/ansys-meshing/
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 05:53
[blockMesh] error Meshing a 3D cube geometry with blockMesh GodOfLove OpenFOAM Meshing & Mesh Conversion 5 July 14, 2009 16:30
Question: Geometry file for Gambit yueke FLUENT 0 May 28, 2009 10:55
Creating geometry & meshing using Gambit Ray FLUENT 3 August 1, 2000 04:30
