August 24, 2011, 03:15 |
heat transfer using ansys
Aly
Rep Power: 15 |
Hi ,
I spent much time trying to figure out how to make the heat transfer analysis for moving fluid inside pipe all I want to do is to pass a flow of air into a pipe , have a cooler half way , and come out with the results (pressure , density , mass flow rate , temperature) at the end of the pipe I'm trying with cfx now please help |
September 7, 2011, 09:05 |
Rep Power: 16 |
Aly,
Using CFX, you can define two domains (just the pipe and the fluid) and connect them through a thermal interface. You can impose a flux at the point the cooler would be and track the fluid, just set up the geometry in DM ("pipe in pipe"). Best regards, Graham |
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade | Karkoura | CFX | 0 | March 10, 2011 16:35 |
Help with mass transfer in heat and water vapor exchanger | mullenc525 | CFX | 7 | January 26, 2011 00:26 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 7, 2008 00:17 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
exporting heat transfer coeff. to ANSYS | H.K.MANAT | FLUENT | 0 | November 30, 2001 07:46 |
