June 28, 2011, 14:32 |
Refresh vs Update - What's the Difference?
Rep Power: 15 |
What is the difference between these three in Ansys 13 Workbench:
- Refresh Project - Update Project - Update Design Points Specifically, which should I click in workbench if... 1. ...if I change an input parameter value and I want to write over the old value? 2. ...if I am exporting DPs (boxes at right in Table of Design Points checked)? 3. ...if I define a new output parameter in CFD-Post, and then I return to Workbench and I want to populate the newly-defined parameter in my Table for all the DPs? 4. ...if I redefine an existing output parameter in CFD-Post, and then I return to Workbench and I want to see the new values of that redefined parameter in my Table for all the DPs? Do all three of these commands force the solver to re-run in all cases? Does one of these commands access already-generated info from CFD-Post so that the solver does not have to re-run in order to populate output parameters in the Table of Design Points? |
ansys 13 work bench, design points, refresh, update |
Periodic Boundary Condition for upwind difference | yohey44 | Main CFD Forum | 0 | October 27, 2010 14:10 |
[General] paraview - plotting difference to reference data | joewe | ParaView | 0 | August 30, 2010 19:01 |
difference between PISO and doubleSIMPLE | CFDtoy | Main CFD Forum | 0 | November 6, 2009 14:32 |
the effect of upwind difference | hades | Main CFD Forum | 8 | March 15, 2009 00:43 |
Fininte difference and Finite element Technique | Mahendra Singh Mehra | FLUENT | 3 | December 23, 2005 00:49 |
