residual spikes in fluent for airfoil case
Old   May 24, 2011, 20:30
Default residual spikes in fluent for airfoil case
Mike
josip76 is on a distinguished road
Im running a test on an transonic airfoil at M=0.73 and Re=6.5E6 im using the density based solver in FLUENT and the spallart-allmares turlence model. I've been having a problem getting the solution to converge even with a low Courant number of 4 (which is low since using implicit solver) and low URF's around 0.2. The force monitors of the drag, lift and momentum do not converge before the equation's residuals begin to spike. The force monitors are what im most interested in since im looking at performance of the airfoil. I built the mesh in ICEM and noticed that the best results in fluent are gotten when the spacing of the first node off the wall is at y+=10 (limit S-A). Also when more nodes are added in the y-direction the case diverges in FLUENT. The y-velocity is begins spiking early durring the itterations and then the energy, x-velocity, and continuity join in later on. However the trubulance residual continues to converge. I was wondering what could be cousing these spikes. Heres a picture of the residuals plot starting at the 2000 iteration point when things start to go bad and thanks for all help
josip76 is offline   Reply With Quote
icoLagrangianFoam OF1.6 myNewParticleSolver heavy_user OpenFOAM 23 June 2, 2020 03:18
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Low Mach number Compressible jet flow using LES ankgupta8um OpenFOAM Running, Solving & CFD 7 January 15, 2011 14:38
Error log vw.cfd OpenFOAM 6 August 7, 2009 06:44
TurbFoam problemlarge Co number sunnysun OpenFOAM Running, Solving & CFD 6 March 10, 2009 09:05
