compressor shroud clearance
Old   May 18, 2011, 11:08
Smile compressor shroud clearance
Selina_stj is on a distinguished road
Hi everyone, for last few months, I use CFX 12 to simulate the compressor fluid without acitivating the shroud clearance by setting wall boundaries to the interface at the tip of blades. But to simulate the real flow, now I have to change the wall boundary of the shroud tip of blades to the interface with conservative flux.
Now I solve the new solver file with the results from the one with the wall boundary of shroud tip as initial results. The problem is the file refuse to run and the error information is as follows:
| An error has occurred in cfx5solve: |
| Indirect start method returned non-zero exit code |
| Indirect solver job failed |
Anybody could give me some suggestions or instructions?
PS: the pictures of the meshes and the two kind of boundaries setting are attached
File Type: jpg 2nd_GGI_Interface boundary for shroud tip.jpg (74.3 KB, 33 views)
Selina_stj is offline   Reply With Quote
Old   May 18, 2011, 21:01
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
post pics of mesh along with boundary conditions
Far is offline   Reply With Quote
Old   May 19, 2011, 11:07
Hi Far, thank you for your reply. The pictures is added to my questions
Old   May 19, 2011, 14:14
Far
Sijal
why you want to create the interface between the tip and casing? is there any special requirement to do so i.e. are you going to run the casing treatment case?
Old   May 19, 2011, 14:23
Hi Far, the interface is generated automatically in TurboGrid.
And it's helpful for me because my meshes is too big. If I run the simulation immediately with the whole mesh. It's impossible to converge(actually, I don't know why). Then I try to close the shroud tip first by defining the wall boundaries to the GGI interfaces generated by the TurboGrid. This definition can stop the shroud tip fluid flow to other passages.
And then after this simulation converged I change the wall boundaries to interface boundary(with conservative flux). This interface boundary allow the shroud tip fluid flow to other passages which is the requirement for the real flow. And then I run the new solver file with the initial results from the simulation of the one with wall boundary to the shroud tip flow.
I hope this explonation is clear that you can see the problem.
Old   May 19, 2011, 14:50
Far
Sijal
this interface is perpendicular to blade tip surface?
Old   May 19, 2011, 15:04
yes, you are right
Old   May 20, 2011, 06:11
Far
Sijal
instead of using the last run as initial guess and changing the wall to interface, make the new file in CFX pre with all conditions you want to simulate.
It will surely work
Old   May 20, 2011, 06:18
It will surely work
Hi Far, Thank you for your suggestions. I tried before as you suggested . But it could not work because my meshes is too big and too complacated. Why I set the shroud tip boundary to wall just because I want to get a first convergent result and then use is as an initial result. I'm so conused with the simulation now.
Old   May 20, 2011, 14:06
Far
Sijal
because my meshes is too big .
How many no of nodes are there ?
If I run the simulation immediately with the whole mesh..
We always with the whole mesh, no matter how big it is. If CFX is not giving any while loading it, which clearly shows that the mesh is not beyond the capability of your computer.
Can you please past the pic with the clear indiction of blade, splitter, inlet, outlet and periodic boundaries. How many chords your in and out boundaries are placed with respect to blade?
Can you put your convergence plots here please? Are you taking autotime scale, physcial time or local. By default it takes the autotime scale with 1/0.2 omega. please see the user guide for detailes.
And then after this simulation converged I change the wall boundaries to interface boundary(with conservative flux). )
Well this is not the standard procedure.
compressor, not run, shroud clearence
[ICEM] Turbine blade with filleting and tip clearance Pursuor ANSYS Meshing & Geometry 4 July 7, 2010 14:56
Meshing in tip clearance. me Siemens 0 August 25, 2008 04:20
Tip Clearance Liam CFX 3 September 7, 2005 06:30
Tip Clearance Drona CFX 0 October 17, 2002 06:25
Convergence when clearance selected dandy CFX 3 November 14, 2001 12:06
